Modelism - RHC Forum: Maverick strada drift evo brushless - Modelism - RHC Forum
#1 Useril este offline   Sergio
  • Postari: 225
  • Inregistrat: 26-February 11
Postat 20 December 2014 - 01:01 PM
Va rog frumos sa ma ajutati cu o informatie!
Am cumparat un automodel sh si vreau sa stiu daca-i pot pune un lipo 3s pe el.
http://www.hpiracing...?partNo=MV12612
Este stock, am pus un 2s si era logic sa mearga dar mi-e frica sa incerc cu 3s... sa nu ard regulatorul.
Stie cineva daca suporta 3s acest automodel?
Multumesc
#2 Useril este offline   vgeorge
  • Membru Fondator MDT
  • Postari: 2700
  • Inregistrat: 31-August 09
Postat 20 December 2014 - 01:54 PM
Dar pentru ce vrei 3s?
Racing
-Associated B7 - buggy 2wd electric
-Associated B74.2 - buggy 4wd electric
-Mugen MTC2 - stock/mod touring electric
-Associated SC6.2 - short course 2wd electric
-Losi SCTE 2.0 - short course 4wd electric
-Mugen MBX5T - truggy nitro
-Mugen MBX6 - buggy nitro
-Kyosho MR03 - 1/28 box stock
-GLR racing - 1/28 mod
-Garbage collection - Crawler performance scale
[center]Club
C.S.T.A. Bucuresti
#3 Useril este offline   hassel
  • Postari: 2464
  • Inregistrat: 02-February 12
Postat 20 December 2014 - 03:16 PM
Specification
  • Continuous Current: 45A
  • Burst Current: 220A
  • Resistance: 0.0012 ohm
  • Application: 1/10 scale on-road and off-road
  • Motor Limit:
  • 2S LiPo or 6 cells NiMH - On-road: ≥9T, Off-road: ≥12T, 3650 size motor
  • 3S LiPo or 9 cells NiMH - On-road: ≥12T, Off-road: ≥18T, 3650 size motor
  • Battery: 4-9 Cells NiMH or 2-3S Lipo**
  • Built-in BEC: 6V/2A
  • Program Port: Multiplexed with cooling fan port
  • Motor Type: Sensorless Brushless
  • Dimension: 48.5 x 38 x 32mm
  • Weight (with wires): 90g
**1) For 4-6 cells NiMH or 2S Lipo: You needn't change the 5V cooling fan on the ESC;
**2) For 7-9 cells NiMH or 3S Lipo: You must change the original 5V cooling fan to 12V cooling fan, or supply the 5V cooling fan from the receiver (5-6V);
Aceasta postare a fost editata de hassel: 20 December 2014 - 03:17 PM
BAJA
5SC 30cc gas
#4 Useril este offline   Sergio
  • Postari: 225
Postat 20 December 2014 - 04:15 PM
Vezi postareavgeorge, la 20 December 2014 - 01:54 PM, a spus:
Pt o viteza mai mare. Fiul meu nu o foloseste pt drift ci pt asfalt. Punem in parc niste obstacole si facem un circuit...
Multumesc pentru raspuns!
#5 Useril este offline   Sergio
  • Postari: 225
Postat 20 December 2014 - 04:17 PM
Vezi postareahassel, la 20 December 2014 - 03:16 PM, a spus:
Specification
  • Motor Limit:
Multumesc pt raspuns! Fiind foarte frig, cred ca este suficient racirea pe care o are! Ce parere aveti?
#6 Useril este offline   Sergio
  • Postari: 225
Postat 20 December 2014 - 04:32 PM
Aici scrie ca trebuie sa schimb cooling fan-ul dar, eu nu am nici un ventilator pe esc. Am doar un radiator... se poate pune un ventilator peste radiatorul actual?
#7 Useril este offline   hassel
  • Postari: 2464
Postat 21 December 2014 - 12:19 AM
Vezi postareaSergio, la 20 December 2014 - 04:32 PM, a spus:
se poate pune si un ventilator legat din receptor pe plus si minus daca e de 5v sau daca e de 12v direct din lipo. Cu un gearing corespunzator la 2s nu e probabil nevoie de ventilator dar cu 3s e posibil sa ai nevoie.
BAJA
5SC 30cc gas
