1. HK450 CCPM cu multe upgrade-uri de V2
Elicopterul are:
Motor : Turnigy Typhoon 450H 2215H Heli Motor 3550kv :http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11041
servo coada : D922MG Digital Metal Gear Servo 1.8kg
servo swash : HXT900
ESC : TowerPro H40A
Pale : 325mm Fiber Glass Main Blades
Gyro : HobbyKing GA-250 MINI-MEMS Gyro
Upgrade-uri:
-HK-450 Main rotor head assemply upgrade ( metalic) : https://www.hobbykin...?idProduct=9790
-GT450PRO Tail Assembly (Belt Version) : https://www.hobbykin...idProduct=11595
- HK450V2 Tail Holder
- HK450V2 Horizontal Fin Band
- HK450V2 Metal Landing Skid
- HK450 carbon tail boom
- HK450V2 Tail Servo Holder
- HK450V2 Tail Drive Gear Set
- HK450V2 Carbon Fibre & Metal Tail Support Rod
- Fiberglass canopy
Piese de schimb:
- Main Rotor Blade Assembly Tool (5mm)
- R/C Helicopter Pitch Gauge
- HK450 Tail Holder (plastic)
- HK450V2 Stabilizer Bar
- HK450V2 Tail Blade
- HK450V2 Plastic Horizontal / Vertical Tail Fin
- HK450V2 Plastic Vertical Tail Fin
- HK450V2 Stabilizer Blade
- 1 x HK450V2 Main Shaft
- Plastic Tail Servo Holder
- HK450V2 Timing Belt
- HK450V2 Feathering Shaft Set (2 set x 3 shaft)
- Plastic Tail Drive Gear Set
- 325mm Wood Main Blades (Baked finish)
- HK-450 Metal Tail Rotor Shaft upgrade version (HS1203)
- HK450V2 Base Plate
- Heli Canopy Rubber Grommet Small (4pcs/bag)
- 6 x Main Drive Gear
- Original canopy
-Tren aterizare incepatori
-Rotor original
-Valiza transport
-etc
Pret 550 Ron tot pachetul
http://uploads.im/rynLO.jpg
2. Turnigy FBL100 RTF
-foarte putin folosit
-4 acumulatori dintre care 2 noi, fara nicio incarcare
-piesele de schimb se vad in poze ( 2 servo, pale, etc)
Pret 350 Ron
3. Heli FP100 (911) PNF - functioneaza cu statie dedicata sau cu turnigy 9x
Piese de schimb : motor, linkuri, canopie, etc
Pret 80 de lei
4. Mini quad WLtoys V929 Beetle UFO PNF- functioneaza cu statie dedicata sau cu turnigy 9x
-2 acumulatori ( 500 si 600 mah)
-elici de schimb
-placuta centrala schimbata cu o versiune mai noua
Pret 100 Ron
Aceasta postare a fost editata de Unnamed: 23 September 2014 - 01:10 PM
