Modelism - RHC Forum: motor os 120 ax - Modelism - RHC Forum
motor os 120 ax setari default
#1 Useril este offline   zigotu
  • Postari: 231
  • Inregistrat: 29-June 09
Postat 20 May 2014 - 09:51 AM
Ma poate ajuta si pe mine cineva cu setarile default la os max 120 ax.Am aiurit relantiul si nu mai pot seta motorul:(
#2 Useril este offline   mihalyn90
  • Postari: 617
  • Inregistrat: 19-December 13
  • Interests:RC Car, Robotics, Reading, Music
Postat 20 May 2014 - 12:05 PM
Ola,
conform manual:
Check that the needle-valve is closed. (Do not overtighten). Now open the needle valve counter-clockwise 2.5-3 turns to the starting setting.
Link:
http://manuals.hobbi...20ax-manual.pdf
Imagine postata
#3 Useril este offline   zigotu
  • Postari: 231
Postat 20 May 2014 - 12:38 PM
asta este ce da in manual pentru (relanti )
ce nu inteleg e "Close the throttle rotor gradually from the fully
opened position until it is just fully closed"
care e throttle rotor?
opened position until it is just fully closed. (Do
not turn further.) Then, screw in the Mixture
Control Screw until it stops. Now unscrew the
Mixture Control Screw approx. 3/4 turn. This is
the basic position.
#4 Useril este offline   Teo-Costin
  • T.C.I.
  • Postari: 1399
  • Inregistrat: 13-June 07
Postat 20 May 2014 - 12:46 PM
..... butoiasul de la acceleratie, adica cu acceleratia la minim
#5 Useril este offline   zigotu
  • Postari: 231
Postat 20 May 2014 - 08:37 PM
Multumesc mult.am sa incerc cum spune in manual.intre timp daca cineva mai are un os max 120 ax reglat poate imi spune cat e relantiul.
