Modelism - RHC Forum: Sonar chinezesc , se merita? - Modelism - RHC Forum
#1 Useril este offline   agentu50
  • Postari: 75
  • Inregistrat: 29-April 12
Postat 18 April 2014 - 02:06 PM
Specifications
Display: Large Adjustable 128 x 64 Dot Matrix FSTN LCD
Display Size: 41 (W) x 48 (D) mm (1.61' x 1.89' inch)
Backlight: White LED
Wireless Frequency: 433 MHz
Sensor Operating Frequency: 125 kHz
Wireless Sensor Coverage: 90 degrees beam angle
Depth Range: 0.6 ~ 35 Meters (2 ~ 115 Feet)
Wireless Operation Range: 50 Meters (164 Feet)
Water Temperature Sensor: Included in Wireless Sonar Sensor
Temperature unit: °C or °F
Measuring unit: Meters (M) or Feet (Ft)
Bottom Contour: Show true changing of water bottom contour
Memory: Built-in memory stores sonar setting when the unit is turned off
Operating Temperature: -20 ~ 70 °C (-4 ~ 158 °F)
Waterproof design: IPx4 / Level 4 (Spray Water Proof)
Power (main unit): 4 x AAA alkaline batteries (not included)
Power (wireless sensor): 1 x 3V CR2032 Button Cell Battery (included)
Battery life of Wireless Sensor: up to 550 hours in water usage
Item size: approx. 136 (L) x 74 (W) x 30 (D) mm (5.35' x 2.91' x 1.18' inch)
Item weight: approx. 160 g (main unit only)
A incercat cineva , este bun ?
#2 Useril este offline   pol-mol
  • Postari: 16
  • Inregistrat: 28-February 12
  • Interests:Navomodele
Postat 18 April 2014 - 03:01 PM
Vezi postareaagentu50, la 18 April 2014 - 02:06 PM, a spus:
Specifications
Ai lua o piatra si ai dat cu ea in balta. Noroc cu atasamentul, sa-si poata da seama omul despre ceeste vorba.
Specificații
Afișaj : Mare reglabil 128 x 64 Dot Matrix FSTN LCD
Dimensiune ecran : 41 ( W ) x 48 ( D ) mm ( 1.61 " x 1.89 " inch )
Iluminare din spate : Alb LED
Frecventa wireless : 433 MHz
Senzor Frecventa de operare : 125 kHz
Wireless Sensor acoperire : unghi de 90 de grade fascicul
Adâncime Range : 0.6 ~ 35 de metri ( 2 ~ 115 de picioare )
Wireless Interval de functionare : 50 de metri ( 164 de picioare )
Senzor de apă Temperatura : Inclus in Sonar Wireless Sensor
Temperatura de unitate : ° C sau ° F
Unitatea de masura : metri (m) sau picioare (ft )
Contour jos : Arata adevarata schimbare de fund de apă contur
Memorie : Built-in memorie cadru magazine de sonar atunci când aparatul este oprit
Temperatura de operare : -20 ~ 70 ° C ( -4 ~ 158 ° F )
Design rezistent la apa : IPX4 / Nivelul 4 ( Spray Apă Proof )
Putere ( unitatea principală ) : 4 baterii alcaline AAA ( nu sunt incluse )
Putere ( senzor wireless ) : 1 x 3V CR2032 Cell buton baterie ( inclus )
De viață a bateriei de senzor wireless : până la 550 de ore in consumului de apă
Dimensiune element : aprox . 136 ( L ) x 74 ( W ) x 30 ( D ) mm ( 5,35 " x 2.91 " x 1.18 " inch )
Greutate element : aprox . 160 g ( doar unitatea principală )
La cati bani ai dat pe el, merita.
Aceasta postare a fost editata de pol-mol: 18 April 2014 - 03:04 PM
#3 Useril este offline   agentu50
  • Postari: 75
Postat 18 April 2014 - 04:57 PM
Nu l``am cumparat inca , pretul e undeva la 80 $ . Se poate modifica distanta de la 50 m undeva la 200-300 metri ? Care ar fi costurile de modificare ?
#4 Useril este offline   ipsihi
Postat 18 April 2014 - 10:27 PM
...cam 100E !!!
#5 Useril este offline   unu nou
  • Postari: 69
  • Inregistrat: 17-March 09
Postat 20 April 2014 - 10:46 AM
..vezi ca sunt si mai ieftine ..la acelasi caracteristici..
#6 Useril este offline   sorinsabadac
  • Postari: 67
  • Inregistrat: 31-July 15
Postat 08 November 2016 - 03:52 PM
Transmission frequency: 433.92MHZ
2. Operating Voltage: DC 3V -12V
3. Modulation: ASK
4. Quiescent Current: 0uA
5. Working current: 8-10mA
6. Code Type: Learning code (eV1527)
7. Radiation power: 10-15mW
8. Transmission Distance: 100-200 meters (receiver sensitivity of -108dBm)
Application:
1. The long-distance wireless remote control;
2. All kinds of anti-theft alarm system;
3. A variety of low-rate wireless transmission of digital signals;
4. All kinds of household appliances, intelligent toys, remote control, etc.
A7518.1A7518.5A7518.6A7518.2A7518.3A7518.4
Penntru a nu deschide alt topic cu acelasi gen de subiect o sa scriu pe acesta.
As dori sa stiu daca transmitatorul pe care l-am atasat mai sus poate fi montat pe ratusca unui sonar de genul celui prezentat in acest topic pentru ai mari puterea de transmisie. Va multumesc
#7 Useril este offline   sorinsabadac
  • Postari: 67
Postat 08 November 2016 - 05:21 PM
Sau acesta e bun?:Descriptions:
Note: This is vedio:v.youku.com/v_show/id_XMTU0MjQwNDU0NA==.html?from=y1.7-1.2
Supply voltage: 12V
Working current: 300-400mA, power adapter recommended over 500mA Low ripple power supply
Dimensions: 55x40x30 (LxWxH), excluding projecting portion
Weight: 56g (g)
Overview:
Amplifier Type: A class of linear amplification
Input power: -20 ~ 3dBm
Output Power: 33dBm (2W) Max
Maximum gain: 42dB
Can be used for FM (88-108) transmit ,power pre-apmlifier, UV segment intercom power amplifier, 433MHz data transmission amplification.
Several important data:
55MHz output at 33dBm (2W), gain 40dB
100MHz output at 32dBm (1.6W)
500MHz output at 30dBm (1W), gain 30dB, below there are test images
600MHz at the output 29.2dBm (0.83W), below there are test images
700MHz at the output 28.6dBm (0.63W), below there are test images
800MHz at the output 27.5dBm (0.56W), below there are test images
900MHz output at 26dBm (0.4W), below there are test images
Packaging
1pcs*  42dB 1Mhz-800Mhz 433Mhz RF UVF Linear power Amplifier HF FM
#8 Useril este offline   witman
  • Postari: 3
  • Inregistrat: 27-November 11
Postat 17 November 2016 - 10:27 PM
http://www.horizonfi...lus_finder.html
Foarte util!
#9 Useril este offline   sorinsabadac
  • Postari: 67
Postat 18 November 2016 - 09:37 AM
Vezi postareawitman, la 17 November 2016 - 10:27 PM, a spus:
Exact acest sonar il detin, cumparat de pe ebey si sunt foarte multumit de el problema e ca initial mergea la o distanta destul de mare dar acum dupa 80 m pierde semnalul , mi sa recomandat sa ii pun amplificator de semnal dar nu stiu cam ce specificatii ar trebui sa aiba acesta
#10 Useril este offline   manolo
  • Postari: 3539
  • Inregistrat: 25-May 08
  • Interests:Navo
Postat 18 November 2016 - 11:31 AM
Acum depinde si de pretentii,singurul sonar care l-am montat si intradevar se vedea perfect fundul apei a fost un full-color fishfinder lowrance hook 4x wireless ,modificat undeva prin Olanda ar fi singurul care l-as monta pe barca mea ,dar caci exista un dar ,timpul ca sa cartografiezi o balta (o bucata daca este mare) este enorm.
Barcute intinse!
#11 Useril este offline   sorinsabadac
  • Postari: 67
Postat 18 November 2016 - 12:00 PM
Vezi postareamanolo, la 18 November 2016 - 11:31 AM, a spus:
De obicei fac partide scurte de pescuit de 14-18 ore si nu am prea mult timp pentru cartografiat fundul apei , ma intereseaza adincimea si ce fel de substrat are fundalul( mil , pietris etc) iar sonarul pe care il am isi face destul de bine treaba chiar daca e low-cost
#12 Useril este offline   manolo
  • Postari: 3539
  • Interests:Navo
Postat 18 November 2016 - 01:37 PM
Daca iti e bun si esti multumit foarte bine ,acum cu 80m daca modelul este cu acumulator vezi ce tensiune ai pe el,daca este cu baterie incearca cu una noua buna.
Barcute intinse!
#13 Useril este offline   sorinsabadac
  • Postari: 67
Postat 18 November 2016 - 02:31 PM
Sonarul este cu acumulator si tine destul de mult incarcat, il incarc o data la citeva luni, o sa il desfac sa verific tensiunea acumulatorului
#14 Useril este offline   witman
  • Postari: 3
Postat 19 November 2016 - 10:08 AM
Dețin sonarul HORIZON STANDARD PLUS FINDER ("o chinezărie" modificată de englezi - nu cred că este asemănător integral cu cel achiziţionat de tine ). Este foarte util, dacă nu ai pretenţii foarte mari de la un sonar. Nu am avut probleme cu el nici la 450 m (distanţă măsurată pe wikimapia)! Din punct de vedere al raportului calitate/preţ, nu cred că ai putea găsi ceva mai bun şi mai versatil!
#15 Useril este offline   sorinsabadac
  • Postari: 67
Postat 19 November 2016 - 12:00 PM
Sonarul este identic cu cel de la horizon iar madificarea care spui tu este la ratusca si consta in faptul ca au adaugat acea antena lunga neagra perntru ca antena originala a ratustei este foarte scurta si este integrata in interiorul ratustei( nu cred ca au facut alta modificare ). Aceeasi modificare am facut si eu la ratusca si initial timp de vreo doi ani sonarul mergea fara probleme la peste 200 m dar acum nu mai merge cind trece de 80-100 m incepe sa piarda semnalul citeva secunde dupa mai merge un pic si iar il pierde . o sa incerc sa schimb ratusca sa vad daca asta e problema
#16 Useril este offline   ionutu
  • Postari: 91
  • Inregistrat: 19-February 14
Postat 19 November 2016 - 12:38 PM
pana la urma orice sonar este bun daca cunosti bine balta,repet,daca cunosti bine balta,adica substrat,conformatie,adâncime,astfel inveti sa-l citesti...
#17 Useril este offline   sorinsabadac
  • Postari: 67
Postat 21 November 2016 - 10:10 PM
[quote name='ionutu' timestamp='1479551923' post='870965']
Pai daca cunosti bine balta la ce iti mai trebue sonar, eu cred ca sonarul este cel mai util pe baltile care nu la cunosti pentru a gasi locurile cele mai bune de pescuit
#18 Useril este offline   ionutu
  • Postari: 91
Postat 22 November 2016 - 04:58 PM
...sa inveti sa-l citesti...
#19 Useril este offline   ahmoola
  • Postari: 409
  • Inregistrat: 14-February 13
Postat 22 November 2016 - 05:17 PM
Super tare.
Sonarul e bun daca cunosti balta....
Sonarul e bun ca sa cunosti balta.....
De parca atunci cand te duci pe balta cunoscuta sau nu ai fi singur!
Sau bagi barca in apa si treci cu ea peste locurile la altii, fire etc... care sunt pe balta de 24-48 ore.
Asadar eu zic ca sonarul e bun sa gasesti pe vadul tau ceva care sa te ajute la pescuit. si daca nu gasesti, ce faci? Pleci? Sa fim seriosi.
In rest fir intins.
#20 Useril este offline   ionutu
  • Postari: 91
Postat 22 November 2016 - 07:05 PM
eu m-am referit la cum poti învata sa citesti un sonar sau mai bine zis cum sa-l intelegi,bineânteles, daca cunosti bine balta,acum fiecare intelege ce vrea...()...la fel...fir intins...!!!!
#21 Useril este offline   ionutu
  • Postari: 91
Postat 22 November 2016 - 07:47 PM
Vezi postareaionutu, la 22 November 2016 - 07:05 PM, a spus:
Aceasta postare a fost editata de ionutu: 22 November 2016 - 07:48 PM
#22 Useril este offline   ionutu
  • Postari: 91
Postat 22 November 2016 - 07:49 PM
