Transmitter modules:
a) Model:DFT
Compatible with the following transmitters:
Futaba: 3PM, 3PK, 7U, 8U, 8J, 9C, 9Z, 10C, FN series, T10C, FC-18, FC-28.
Hitec: Optic 6, Eclipse 7, Prism 7.
WFLY: WFT09, WFT08.
1.1 Receiver module:
a) Model:D8R
Compatible with FrSky Two Way moduleDFT/DJT.
2. Function of Two Waycommunication
a) Two way communication between receiver and transmitter
Receiver is able to accept 2 analog inputs, which can be used to monitor batteryvoltage, temperature sensor, etc., and transfer them to transmitter. Users can set the Alarm Level of these analog voltages, when exceed or below theselevers, sound alarm is issued.
Receiver is able to accept serial data streams from simple 3-wire RS232 port, such information as GPS, altitude, and user developed data can be transferred to Tx without error, and sent at theRS232 port on the Tx
2.1 Receivers pecifications:
Model: D8R
Weight: 16.2g
Dimension: 54*27*17mm
Operating Voltage Range:4.0V-7.2V
Operating Current: 100mA
Specified Range: 1.5km (Ground Range)
Resolution: 11bit (3072)
Latency: 22ms
Number of Channels: 8CH
Analog voltage: 0~3.3V
2.2 Transmitter module specifications:
Model:DFT
Operating Voltage Range:6.0V-13.0V
Operating Current: 50mA
Output Power: 60mW
Pret 250 RON, detalii – 0722123134
