Aceasta postare a fost editata de worms: 27 September 2011 - 01:17 PM
cnc made in china maruntisuri de pe e-bay
Postat 27 September 2011 - 01:14 PM
Postat 27 September 2011 - 01:27 PM
Aceasta postare a fost editata de worms: 27 September 2011 - 01:27 PM
Postat 27 September 2011 - 01:30 PM
This is a new 3-axis cnc router
production design your own 3D models and 3D works of art,
Can use it to carving PCB board,
The routers use precision linear bearings and alloy manufacturing,
Linear bearings, can be adjusted to ensure the elimination of the gap,
precision fit,
high-precision linear Round rails, diameter 0.8-inch,
The use of high-precision new ball screw,
there is no rebound in return; diameter 16 mm; pitch 10 mm;
Aluminum alloy T-slot table, Can help you cut and fixed,
Manufacture than wood table has a huge advantage,
NEMA23 stepper motor current is 3A, the weight 2.2 pounds ,Torque 1.7n.m 245 oz.In.
30v 3A CNC drive,tb6560 , Optical isolation, the maximum 1 / 16 micro-step,Spindle control relay
400w 30v Switching Power Supply
Router is the length of 34 inches, width is 28 inches, 85cm 67cm
Effective processing distance: X = 24 inches,Y = 16 inches, Z = 4 inches (63cm 39CM 10CM)
Highly rigid structure, the weight of 120 pounds, 60KG,
Can be used in all countries of the world, power is the input voltage 110v --- 240v AC
Default spindle is ; power 400w; 6 speeds; 1000-30000RPM
This is High accuracy; mach3 software can control the speed and direction;
run M3 and M4 M and S codes;
Postat 27 September 2011 - 06:53 PM
Maruntis ... bine , da' cam cat , daca nu sunt indiscret ?
Ce anume vrei sa reglezi la el ? Ai setup-ul de la Mach3 ( fisierul xml ) ? Sa inteleg ca inca n-ai testat nimic ?
Ai reusit sa-l misti ? Ce motor de frezare vrei sa pui ?
Aceasta postare a fost editata de katran: 27 September 2011 - 06:55 PM
Postat 27 September 2011 - 10:00 PM
Aceasta postare a fost editata de worms: 27 September 2011 - 10:01 PM
Postat 27 September 2011 - 10:13 PM
Erau prin romanica destui bajeti experimentati care ar fi putut sa iti vanda un cnc, mai bun decat acest zgarieci. Facut de ei, tot cu piese chinezesti, dar macar gandit si probat.
In rest...sa ai succesuri maxime!
Aceasta postare a fost editata de BogdanStancu: 27 September 2011 - 10:13 PM
Postat 27 September 2011 - 10:56 PM
BogdanStancu, la 27 September 2011 - 10:13 PM, a spus:
e un punct de vedere pe care nu-l impartasesc dar il respect si argumentatia mea consta in faptul ca producatorul meu( o fabrica) a vandut in ultimii doi ani cam 2000 de bucati si are calificative 100% pozitive deci de unde concluzia ca nu e de pe drumuri cum pare si cu tot respectul dar eu zic ca de experienta in constructie nu se pune problema .cand dai niste bani mai multi pe e-bay te mai si interesezi cu cine vrei sa faci o afacere,eu cel putin asa fac.daca gresesc vedem in zilele urmatoare :)
Aceasta postare a fost editata de worms: 27 September 2011 - 10:58 PM
Postat 28 September 2011 - 09:25 AM
Probabil ca o sa-ti faci singur altul ( mai mare , mai robust , mai precis ) , dar deocamdata , pentru inceput , este absolut
perfect asta . Ai ocazia sa inveti ce si cum , sa vezi daca merita sau nu ... Din partea mea , tot respectul .
Acuma ... in teorie , exista o ordine de montare / aliniere a masinii ... presupun ca nu ai doua maini stangi , asa ca n-o sa fie
o problema pentru tine chestia asta. Greseaza rulmentii , suruburile conducatoare . Verifica unghiurile de 90 de grade , alinierile
masinii ( ar fi necesare un comparator si un vinclu master / de precizie ) . Mare atentie la blocurile de rulmenti si piulite ( varifica
suruburile , sa n-ai backlash ). Daca ai rulmenti radiali axiali , ai grija cum montezi tarasenia ( rulmentii aia trebuie montati cap in cap ,
astfel ca la strangere , sa se elimine jocurile axiale / backlash-ul ) . Greseaza piulitele de la suruburiel alea cu bile ... cel mai bine
ar fi sa le dai afara , sa speli bine tot ( scapi de spanul ramas de la prelucrare ) , numeri bilele si le montezi corect inapoi ...
La partea de electronica cred ca nu ai nevoie de sfaturi ... in cel mai rau caz , te duci la kelinginc pe site , si la sectiunea documents gasesti
absolut toate schemele si diagramele de conectare / specificatii de care ai nevoie ...
Succese !!!
Postat 23 December 2011 - 07:55 PM
"Router is the length of 34 inches, width is 28 inches, 85cm 67cm" sau
"Effective processing distance: X = 24 inches,Y = 16 inches, Z = 4 inches (63cm 39CM 10CM)"
va întoarce ca rezultate niște licitații încheiate cu prețuri de genul:
US $1,090.00 + Shipping: US $430.00 Economy Int'l Shipping
Winning bid: £661.00 + Postage: £230.00 - Economy Int'l Postage
Deci cu totul estimez un aproximativ de $1400 - 1500$. Asta dacă nu revine worms și ne dă mai multe detalii...
