Castle Creations Phoenix-60 Brushless ESC + Castle Link PC 118$ + 22$ 430RON
FEATURES:
High Rate Adjustable Switching (PWM)
Up to 60A Continuous Current with Proper Air Flow, 80A surge
Five to Ten Cells with Four Micro Servos
Up to 12 Cells with Three Micro Servos
20 Cells Max (With BEC Disabled)
Dynamic Braking Ensures Folding Props Fold Promptly BEC (3A) Provides Power to Receiver and Servos User Programmable
Low Voltage Cutoff
Over Current Protection
Brake Type Throttle Range-Fixed/Self Adjusting/Governor
Timing Advance Cutoff Type Soft Start Ramp Up
Switching Frequency Runs Motor in Forward or Reverse
Auto Motor Cutoff with Reset Safe "Power On" arming program ensures motor will not accidentally turn ON
Low Torque "Soft Start" Prevents Damage to Fragile Gearboxes
Auto Shut Down When Signal is Lost or Radio interference becomes severe
Input Voltage: 5-12C w/BEC 5-20C Max w/BEC Disabled
Resistance: .0012 Ohm Low Voltage Cutoff: Programmable
Switching Rate: Programmable (11kHz, 22kHz, or 41kHz)
SportBEC Switch-mode BEC Dimension Engineering 30$ 90RON
Specifications: Input voltage: 9V to 33.6v (3s-8s lithium, up to 21 NiMHs)
Output current: 3.5A (~8 standard servos, 4-6 digital)
Weight: 13g/.46oz (including wires)
Universal connector fits all receivers
Applications: Sport aircraft, .40 to 1.20 glow conversions, Helicopters, 3d aircraft
Scorpion HK-2221-8 V2 Brushless Motor (3595Kv) 79$ 240RON
Stator Diameter: 22.0 mm (0.866 in)
Stator Thickness: 21.0 mm (0.827 in)
No. of Stator Arms: 9
No. of Magnet Poles: 6
Motor Wind: 8 Turn Delta
Motor Wire: 16-Strand 0.21mm (31 AWG)
Motor Kv: 3595 RPM / Volt
No-Load Current (Io): 2.31 Amps @ 10 volts
Motor Resistance (Rm): 0.024 Ohms
Max Continuous Current: 45 Amps
Max Continuous Power: 475 Watts
Weight: 79 Grams (2.79oz)
Outside Diameter: 27.9 mm (1.097 in)
Shaft Diameter: 3.17 mm (0.125 in)
Body Length: 33.6 mm (1.323 in)
Overall Shaft Length: 57.0 mm (2.244 in)
3X Hitec HS-65 Metal Gear 87$ 260 RON
Weigth: 0.44oz (12.5g)
Speed: 0.14sec/60° @ 4.8V
0.11sec/60° @ 6V
Output Torque: 24.99 oz-in (1.8 kg-cm) @ 4.8V
30.55 oz-in (2.2 kg-cm) @ 6V
Futaba GY401 Gyro w/S9254 Digital Servo 229$ 700RON
RX Fuaba R617FS 90$ 270RON
Kit CopterX 450SE, echivalentul T-REX 450 Sport 55$ +
Pale Align 335 11$ +
Pale de rezerva Carbon Hobby 14$ +
Pale de rezerva echilibrate lemn 4$ +
Pale de rezerva coada Carbon Hobby 10$ = 290RON
Align Metal Tail Drive Gear Assembly HS1216-84 (nu este montat) 8$ +
Align Tail Pitch Assembly HS1304 (nu este montat) 7$ +
AlignTail Rotor Control Arm Set (HS1277A) (nu este montat) 5$ = 60RON
Canopy Fiber Glass 10$ +
Teren de aterizare metalic 9$ +
Power meter Robbe 5$ = 70RON
Thunder Power 2700mAh 3S 11.1v 30C 49$ 150RON
Incarcator cu balancer Battery Hobby 40$ 120RON
Cutie de aluminiu 35$ = 100RON
Aparatul are 3 zboruri la activ, 0 crashuri.
Nu se vinde pe piese, insa accept oferte. Daca se aduna clienti pentru toata electronica va contactez.
Nu ma intereseaza parerile asupra KIT-ului, din partea mea considerati-l gratuit. Tot ce pot sa va spun este ca e apropiat ca si calitate de original (T-rex 450 Sport), cadrul este fibra de carbon de inalta calitate iar capul tine extrem de bine
Nu stiu daca are rost sa mai mentionez pretul de plecare in $ fara TVA sau totalul rotunjit de 2700 Ron.
Pretul final este de 1599 RON.
Contact prin PM
Vand kit complet ARTF clasa 450 Sport, cea mai performanta electronica CastleCreations, Scorpion, Hitec MG, Futaba
Postat 09 September 2011 - 02:37 PM
They told me I could be anything...
...so I became a helicopter
Postat 16 September 2011 - 11:57 PM
https://lh4.googleusercontent.com/-Od8MCr_V7fQ/TnPDlXUD8RI/AAAAAAAAAB4/9Yu5KDfY8MM/s800/SANY0183.JPG
https://lh5.googleusercontent.com/-9d7TWvvgmCo/TnPDh2du_PI/AAAAAAAAABw/PrGjBvaSFvw/s800/SANY0179.JPG
https://lh6.googleusercontent.com/-0DIoxTBkTNQ/TnPDYVORhtI/AAAAAAAAABM/uA3VeHipbnY/s800/SANY0166.JPG
https://lh3.googleusercontent.com/-ILHo6iTxLuA/TnPDeUJCSiI/AAAAAAAAABk/kafutfQS7rc/s800/SANY0175.JPG
https://lh4.googleusercontent.com/-OismvEQ7B28/TnPDvigyX8I/AAAAAAAAACU/yH4kL8Lo6es/s800/SANY0191.JPG
Aceasta postare a fost editata de Frochock: 16 September 2011 - 11:55 PM
Postat 23 September 2011 - 09:17 PM
UP, 1500 RON
Postat 29 September 2011 - 11:33 PM
UP 1450.
Pentru cei care se astepata sa cumpere la un pret de nimic, s-ar putea sa aveti surprize.
Postat 09 October 2011 - 12:02 PM
UP
Postat 24 October 2011 - 10:43 AM
Si mai sus!
Postat 19 December 2011 - 11:51 PM
Tare se mai plictiseste in dulap. 1200 RON, negociabil.
Pozele vechi s-au dus, deci daca este cineva cu adevarat interesat am sa pun altele.
Postat 20 December 2011 - 02:48 PM
Imi pare rau dar nu pot sa-ti dau un raspuns acum,depind si eu de altcineva...
