Modelism - RHC Forum: Aeros Stealth - Modelism - RHC Forum
Aeros Stealth
#1 Useril este offline   wabo
  • Postari: 394
  • Inregistrat: 01-April 02
Postat 25 February 2003 - 05:51 PM
Sintem pe cale sa negotiam la Aeros:
http://www.aeros.com.ua
pentru mai multe deltaplane. Daca aici mai este cineva care sa intereseaza sa participe in grup sa dea un semn de viata.
Preturi sint undeva de la 3-4000 EUR adus in tara pe buc.
Salutari
Walter Born
Salutare
Walter Born
#2 Useril este offline   Andrei
  • Postari: 562
  • Inregistrat: 15-March 02
Postat 25 February 2003 - 06:01 PM
Salut Wabo
Ai idee si de pretul unui motodeltaplan? Am vazut pe site-ul lor ca produc si asa ceva
Andrei
#3 Useril este offline   DukeOfWeb
  • Postari: 24
  • Inregistrat: 11-February 03
Postat 25 February 2003 - 06:45 PM
Vedeti ca aia livreaza pe shest Stealth 15, cu materialele cu care fac ei Stranger si Stream, adica cu porcaria aia de Lavsan. Daca au indicator 100D la pinza, in loc de 100, e din materialul lor oribil.
Cascati bine ochii, s-au ars prietenii mei din Franta.
Si cu vama cum faceti ?
bafta multa
#4 Useril este offline   wabo
  • Postari: 394
Postat 26 February 2003 - 08:33 AM
Alo,
exista importator oficial in Romania. Aici aveti preturi si materiale:
Aeros:
Target 16 /for power flight: 1900/1920EUR
Target 13: 1860EUR
Discuss 14: 2550EUR
Stealth KPL3 - 12 (with ALU X-beam): 3390EUR
Combat - 14, 15 (Polyant Matrix sail, carbon X-beam, carbon speedbar,
Bautek uprights, carbon winglets): 3850EUR
Combat 2 - 13, 14, 15 (Banbridge Matrix sail, carbon X-beam, low-drag
A-frame, carbon winglets): 3950EUR
OPTIONS
Carbon airfoil winglets for Stealth (set): 180
Carbon airfoil speedbar for Bautek/Finsterwalder A-Frame: 270
Carbon airfoil speedbar for low-drag A-frame, corner brackets included: 350
Upgrade low-drag A-frame (bottom wires included): 590
RIGID WING
Stalker with WW uprights, carbon speedbar & winglets: 6050
Bautek A-Frame with round speedbar 595
Termen de livrare Fabrica Aeros-Romania: intre 30-45-60 zile, in functie
de cat de multe comenzi au in momentul respectiv.
Importator, daca mai voie löa o reclama este:
www.skysports-team.com din Bacau
Preturi sint cam 20-30% mai jos ca la Germania.
Salutare
Walter Born
Aceasta postare a fost editata de wabo: 26 February 2003 - 08:36 AM
Salutare
Walter Born
#5 Useril este offline   DukeOfWeb
  • Postari: 24
Postat 26 February 2003 - 01:35 PM
E bine ca se face oficial.
Eu zic doar ce s-a intimplat in Franta, sa nu se supere nimeni.
Oamenii au comandat un stealth 15 li s-a zis la fel, ca e cu Dacron si Trilam Dimension Polyant Germany, dar cind a sosit era evident ca parti din el erau dintr-un material inferior, adica Lavsan ucrainean. Adica, pe shest, asa. Cum nu aveau cum sa dovedeasca (ce sa faca, probe chimice ca nu e fir DuPont ?) dupa mult scandal au obtinut sa le schimbe pinza cod 100D cu una cod 100, cu plata transportului si vamei !
Din scandalul asta, uite un raspuns de la Dimension Polyant, apropos de materialele folosite (s-a apelat la ei pentru certificare). Copiez din mesajul original, il am si eu.
Dear sir,
Thank you for your mail and your interest in our fabrics.
We produce cloth for sails to be used on sailboats and yachts. Our styles are not developed to be unsed in Ultra light aircrafts. However, we know that some well known manufacturers of UL's are using our cloth in their products. But we have to inform you that we can not be held liable in any case for special, incidential or consequential damages if our cloth is used for other purposes than recommended.
Kindly note that we only supply to manufacturers. We do not deliver to clubs or private individuals. However, on receipt of your document we will send you our samples of our materials.
Many thank in advance for your understanding.
Mit freundlichen Grüßen / Best Regards
DIMENSION-POLYANT GmbH
Wolfgang Gey
Tel. +49 - (0)2152 - 891 128
Fax: +49 - (0)2152 - 891 149
Hai, numai bine si sanatate la toti !
