Modelism - RHC Forum: DIVERSE ...curatenie. - Modelism - RHC Forum
DIVERSE ...curatenie. pt AERO.
#1 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
  • Inregistrat: 03-February 07
  • Interests:AEROMODELISM
Postat 27 April 2010 - 05:56 PM
1. CON PLASTIC (FII 75 X 8( GAURA INTERIOR ) PRINDERE CAPAC CU 4 SURUBURI ..PT TERMICE DESTINAT! ...16RON
2, ROTI AERO ( CAUCIUC PLIN ) HANGAR 9! ...DIAMETRU 80 X3mm( ax prindere),greutate ambele roti 110g.....17ron ( nefolosite)
3.MOTOR AERO : COMPACT 260Z /11,1V( NOU NOUT) ....30.RON
4 .ESC 33 A....25 RON
5 SISTEM DE ILUMINAT ( AERO , NAVO ,HELI ,MASINUTE) CU 2 TUBURI LUMINISCENTE ( GALBEN FOSFOROSCENT )...65 RON
ADOR VITEZA!!!
#2 Useril este offline   nicolas
  • Postari: 695
  • Inregistrat: 06-October 06
Postat 27 April 2010 - 06:13 PM
Regulatorul il vreau eu.
Its nice to be important, but its more important to be nice ...
#3 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 27 April 2010 - 06:25 PM
Vezi postareanicolas, la Apr 27 2010, 07:13 PM, a spus:
rezervat!
ADOR VITEZA!!!
#4 Useril este offline   gicosu
  • Postari: 1849
  • Inregistrat: 08-May 03
Postat 27 April 2010 - 06:33 PM
Vreau eu rotile!
#5 Useril este offline   tetea
  • Postari: 759
  • Inregistrat: 04-April 08
Postat 27 April 2010 - 06:44 PM
 Vreau eu motorul, lasa-mi te rog un numar de telefon...
#6 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 27 April 2010 - 07:20 PM
Vezi postareagicosu, la Apr 27 2010, 07:33 PM, a spus:
Vreau eu rotile!
rezervate.
ADOR VITEZA!!!
#7 Useril este offline   luc_petre
  • Postari: 41
  • Inregistrat: 06-December 09
  • Interests:aero modelism
    auto modelism
    airsoft
Postat 27 April 2010 - 10:05 PM
salut motorul si regulatorul le vreau eu daca nu le iau baietii
merci si bafta
luc_petre
[url="http://www.youtube.com/watch?v=AnZ8OyGL-4E&feature=channel_page"]
#8 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 28 April 2010 - 11:26 AM
Vezi postarealuc_petre, la Apr 27 2010, 11:05 PM, a spus:
merci si bafta
motor si esc ...vandute!
ADOR VITEZA!!!
#9 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 28 April 2010 - 12:25 PM
Vreau eu rotile!
VANDUTE!
ADOR VITEZA!!!
#10 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 28 April 2010 - 01:09 PM
SE MAI ADAUGA:
1. LIPOL 3 S/2100....(.15 -20 INCARCARI)..STARE BUNA 60 RON
2.CARD PROGRAMARE PT ESC .....15 RON
3 PERECHE DE PALE PT LAMA ( A+B ) FOLOSITE , SUNT CA NOI .....20 RON
4. CON FARA CAPAC CU PALE DE 10X6 ROBBE ( PLIABILE).......30 RON ( NOI)
5 CON FARA CAPAC CU PALE 7X4 PLIABILE.....20 RON (NOI)
6 PALE PLIABILE NOI SIGILSTE 8X4.5 ..........10 RON
7 ELICE APC 5.1X4.5E ..10 RON ( SIGILATA)
8 ELICE APC SPORT 8X4 ( PT TERMICE)...5 RON
Aceasta postare a fost editata de TUROK: 28 April 2010 - 01:10 PM
ADOR VITEZA!!!
#11 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 28 April 2010 - 01:11 PM
CON PLASTIC (FII 75 X 8( GAURA INTERIOR ) PRINDERE CAPAC CU 4 SURUBURI ..PT TERMICE DESTINAT!......15 RON
SISTEM DE ILUMINAT ( AERO , NAVO ,HELI ,MASINUTE) CU 2 TUBURI LUMINISCENTE ( GALBEN FOSFOROSCENT ) 55 RON ( AZI) :rolleyes:
Aceasta postare a fost editata de TUROK: 28 April 2010 - 01:12 PM
ADOR VITEZA!!!
#12 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 29 April 2010 - 09:08 AM
Se mai adauga in lista un motor Brushless2408-21T /KV: 1750
Elice recomandata: 9*4, 8*4
Tensiune: LiPo 2s, sau 3s
30 RON
Motorul nu a vazut curent ! este nou in tipla.
ADOR VITEZA!!!
#13 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 29 April 2010 - 09:59 AM
2408-21t ...poza.
ADOR VITEZA!!!
#14 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 29 April 2010 - 10:14 AM
AC ADAPTOR CU DETECTIE 9V DC/1000mA .......25RON
CON TURBO 40/PRINDERE PE AX MOTOR 5 ......35 RON
CON ALUMINIU 40/PRINDERE PE AX MOTOR 5 .....35RON
Con elice pentru motoare termice.
Diametru: 51 mm
Inaltime: 56 mm
Diametru gaura pentru ax motor: 8 mm
Masa: 29g .........10 RON
Pachet de acumulatori pentru emitator
Conector: tip servo
Tensiune: 9.6 V /850mAH
Dimensiuni: 102 x 30 x 30 mm
Masa: 240 g .....................................50 RON
NOU!
ADOR VITEZA!!!
#15 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 03 May 2010 - 08:53 AM
REZERVAT~ :D
ADOR VITEZA!!!
#16 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 04 May 2010 - 08:50 AM
Vezi postareaTUROK, la May 3 2010, 09:53 AM, a spus:
REZERVAT~ :D
VANDUT :D
ADOR VITEZA!!!
#17 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 05 May 2010 - 05:05 PM
rezervat!
ADOR VITEZA!!!
#18 Useril este offline   DreamFly
  • Postari: 55
  • Inregistrat: 12-April 10
  • Interests:Aero
Postat 05 May 2010 - 09:21 PM
vreau eu motorul daca nu sa dat! ai niste specificatii la el? cam cat ar trage cu elicea recomandata? eu am un cessna de 130 cm din balsa si caut sa cumpar electronica!
#19 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 05 May 2010 - 11:58 PM
Vezi postareaDreamFly, la May 5 2010, 10:21 PM, a spus:
Dimensiuni: diametru: 30.6mm, lungime: 62mm
Diametru ax: 3 mm
Greutate: 46g
Randament maxim: 80%
KV: 1750
Curent de mers in gol: 1.8A
Curent maxim: 14A
Sistemul de prindere: Disc aluminiu pentru prindere pe panou de foc. Optional disponibil piesasa AL, cu radiator de caldura, pentru bagheta 10x10
Se recomanda taierea axului motorului la lungimea minim necesara pentru a evita indoirea acestuia in caz de impact
De asemenea se recomanda utilizarea "prop saver"-ului.
Forta de tractiune statica masurata: cu LiPo 3s, elice 8*4:
8.2A - 343g
11.1A - 485g
13.1A - 600g
elice 8*6: 15A - 650 grame
ADOR VITEZA!!!
#20 Useril este offline   EZ*
  • Postari: 1695
  • Inregistrat: 10-November 04
  • Interests:aero&auto r/c
Postat 06 May 2010 - 09:42 AM
vreau eu palele pliabile de 8x4.5 :unsure: livrare la A51 se poate?
Aceasta postare a fost editata de EZ*: 06 May 2010 - 09:42 AM
#21 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 06 May 2010 - 06:02 PM
Vezi postareaEZ*, la May 6 2010, 10:42 AM, a spus:
vreau eu palele pliabile de 8x4.5 :D livrare la A51 se poate?
imi pare rau , dar nu ajung acolo . :D
ADOR VITEZA!!!
#22 Useril este offline   9unuunu
  • Postari: 802
  • Inregistrat: 07-July 08
  • Interests:flying, skydiving,snowboarding,paragliding
  Postat 08 May 2010 - 01:08 AM
vreau eu sistemul de iluminat :blink:
apropo se pot pune mai multe tuburi pe el??
FLYING IS AN ART
#23 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 08 May 2010 - 05:04 PM
Vezi postarea9unuunu, la May 8 2010, 02:08 AM, a spus:
vreau eu sistemul de iluminat <_<
Decat 2 buc. :)
ADOR VITEZA!!!
#24 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 09 May 2010 - 05:09 PM
Vezi postareaTUROK, la May 5 2010, 06:05 PM, a spus:
rezervat!
vandut! :)
ADOR VITEZA!!!
#25 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 13 May 2010 - 04:53 PM
VANDUTA <_<
ADOR VITEZA!!!
#26 Useril este offline   Zeus
  • Postari: 2455
  • Inregistrat: 15-January 09
Postat 13 May 2010 - 08:34 PM
Un inventar la ce mai e de vanzare se poate?
#27 Useril este offline   Parshulea
  • Postari: 26
  • Inregistrat: 31-May 09
Postat 14 May 2010 - 04:56 PM
ma abonez la elicea plianta de 10 toli.
Daca o sa ajungi la 3d sambata adu-o cu tine.
#28 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 15 May 2010 - 04:28 PM
Vezi postareaParshulea, la May 14 2010, 05:56 PM, a spus:
ASTEA?
AM FOST LA CAMP PANA LA 12:30
ADOR VITEZA!!!
#29 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 17 May 2010 - 07:45 PM
Vezi postareaTUROK, la May 15 2010, 05:28 PM, a spus:
ASTEA?
vandut.
ADOR VITEZA!!!
#30 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 21 May 2010 - 08:44 PM
REZERVAT.
ADOR VITEZA!!!
