LiFePo4 De unde, de ce?
Postat 28 April 2008 - 08:29 PM
Americanii de la A123 (pe ei ii consider cei mai buni) spun ca pentru Europa, putem face comenzi la http://www.bmz-gmbh.com/
Pretul unei celule este de 12 euro. Chiar daca pe site nu am gasit detalii despre aceasta tehnologie, puteti cere detalii prin e-mail.
Sunt curios daca se pot gasi asemenea celule si in tara, dar sa fie A123 sau ceva aproape identic ca am vazut ca au aparut fel de fel de brand-uri.
Pacat ca la noi nu am gasit o anume masina electrica de gaurit Dewalt, pe care americanii o desfac si apoi pun mana pe aceste bijuterii de acumulatori.
Postat 28 April 2008 - 08:51 PM
Postat 28 April 2008 - 11:00 PM
p990i, la 28 Apr 2008, 21:11, a spus:
Am ramas uimit sa vad ca ajung si la peste 7000 cicluri cu o performanta de genul a 75-80% din capacitatea initiala, asta inseamna peste 20 ani :)
1000+ cicluri( din specificatiile producatorului)........7000 e cam tras rau de par
High Power Lithium Ion ANR26650M1
A123Systems’ lithium ion rechargeable ANR26650M1 cell is capable of very high power, long cycle and
calendar life, and is inherently safer due to its use of patented Nanophosphateâ„¢ technology.
Nominal capacity and voltage 2.3 Ah, 3.3 V
Internal impedance (1kHz AC) 8 m0 typical
Internal resistance (10A, 1s DC) 10 m0 typical
Recommended standard charge method 3A to 3.6V CCCV, 45 min
Recommended fast charge current 10A to 3.6V CCCV, 15 min
Maximum continuous discharge 70A
Pulse discharge at 10 sec 120A
Cycle life at 10C discharge, 100% DOD Over 1,000 cycles
Recommended pulse charge/discharge cutoff 3.8V to 1.6V
Operating temperature range -30°C to +60°C
Storage temperature range -50°C to +60°C
Core cell weight 70 grams
Inarcator : Multiplex LN 6015 EQU
Date tehnice:
-Tensiune de alimentare 11 - 15 V
-Celule NiCd (1-15), NiMH (1-15), Pb (1-6), LiIon (1-6), LiPo (1-6), LiFe (1-6)
Aceasta postare a fost editata de zgr_44: 28 April 2008 - 11:09 PM
Postat 29 April 2008 - 06:20 PM
http://a123systems.c...y/life/lchart1/
Sumar: daca se foloseste 1C si se considera ca viata acumuatorului este terminata cand acesta atinge un prag de 80% din capacitatea initiala, atunci rezulta aproximativ 7300 cicluri (am aproximat ochiometric din acel grafic). Daca mergi pe ideea ca poti sa cobori si la 70-75% cred ca sari de 8000 cicluri.
Cand iau in calcul asemenea curenti, ma refer la solutii de back-up, sau de stocare a energiei, pentru solutii alternative.
Sau altii:
http://www.boatweb.com.au/2008/04/24/lithi...e-applications/ (pentru asta va trebui sa dati find in pagina dupa 7000, daca nu vreti sa cititi totul).
Postat 29 April 2008 - 08:00 PM
http://www.allerc.com/images/Pictures/HP-EOS0606i-AD-L.jpg
Postat 04 May 2008 - 11:18 AM
Si eu sper ca firma de comenzi online din tara sa aduca asa ceva http://www.rhcforum....tyle_emoticons/default/wink.gif
Postat 04 May 2008 - 11:39 AM
Si de ce nu am putea cumpara singuri ?
Postat 04 May 2008 - 11:55 AM
Putem cumpara si singuri, tocmai ce am spus cu cat se poate comanda de la nemtii acreditati de americanii de la A123systems, dar daca luam ca exemplu Robbe, am observat o chestie dubioasa: motorul Roxxy Bl Outrunner 5065/09, pe site-ul firmei producatoare l-am gasit la pretul de 95.5 euro, in ron inseamna ~350 ron, la care trebuie sa bagi si transport, pe cand la firma online costa 277 ron la care trebuie adaugat si transportul care este intern. De ce costa mai ieftin la noi nu inteleg, dar daca reusesc si chestia asta la acumulatorii lifepo4, atunci iesim mai castigati, nu?
Postat 04 May 2008 - 11:59 AM
Particular advantages:
Simply connect the BID key to the charger, and the charge process begins.
- No tiresome searching through the menu for the set-up parameters
- Maximum protection from accidental mis-setting
- Essential battery data is stored in the BID key
Of course, the Power Peak Compact charger can also charge batteries not fitted with the BID system.
One BID key is supplied with the charger as standard.
Functions:
- Charge - discharge - cycle (discharge -> charge).
- Setting of charge / discharge current, capacity, battery type and cell count.
- Display of charged-in and discharged capacity.
- Display of charge / discharge time.
- Display of input voltage and charge voltage.
- Display of Equalizer - individual cell voltage, optionally as summary (with two decimal points resolution) or as a list function with three decimal points resolution (1/1000 Volt).
NC / NiMH batteries
- 1 ... 14 cells
- The automatic digital Delta-Peak cut-off circuit switches the charge process off at the correct time, and is set up to match NC and NiMH batteries.
Lithium batteries
- 1 ... 6 cells
- Display of individual cell voltages of Lithium batteries
- Automatic charge cut-off circuit using the CC-CV charge method
Lead-Acid batteries
- 1 ... 6 cells (2 ... 12 Volt)
- Automatic charge cut-off using the CC-CV charge method
Specificatii:
Voltaj intrare: 10 - 15 V
Detectia terminarii incarcarii: automatic
Curent incarcare: 0.1 - 5 A (max. 50 W)
Numar de celule pentru acumulatori NiMH: 1 - 14
Numar de celule pentru acumulatorii LiPo, LiFe: 1 - 6
Numar de celule pentru acumulatorii PbAcid: 1 - 6
Postat 04 May 2008 - 07:22 PM
melsoft, la 29 Apr 2008, 20:00, a spus:
Acelasi aparat il folosesc si eu.
date tehnice:
EOS 0606i 6A max AC/DC Charger
The Hyperion EOS 0606i 6S 6A max AC/DC charger with Integrated LBA balancer charges LiPo, LiFePO4/A123, NiCd, NiMH, and lead-acid cells.
Features:
Dataport for PC software
11v~15V DC and 100v~240V AC Inputs
Hyperion Balance Multi-Adapter included for 2S to 6S Lipo & A123 based packs. Fits Impulse, Hyperion, Polyquest, MaxAmp and similar plugs.
Powerful, yet compact and portable with wide support for battery types
Charge and Discharge Modes (and cycling for NiMH and NiCd)
Aluminum Case
Long Input Leads
Support Battery Types: 1-14cell NiCd & NiMH, 1-6 LiPo, LIon & Lead Acid
Charge Current: 0.1A~6A Max
Discharge Current: 0.1A~1.0A Max
Trickle Charge: 0 ~ 200Mah
Display: 2-Line 16-Character Blue Backlit
Postat 04 May 2008 - 09:09 PM
p990i, la 29 Apr 2008, 18:20, a spus:
Sau altii:
Dat fiind faptul ca inca nu am vazut personal nici un UPS macar pe LIPO nu stiu cat de curand se vor folosii pe LIFE asa ca, aratami si mie un motor electric folosit in modelism care ar consuma doar 1C.
Aceasta postare a fost editata de zgr_44: 04 May 2008 - 09:16 PM
Postat 04 May 2008 - 09:12 PM
p990i, la 4 May 2008, 11:18, a spus:
Si eu sper ca firma de comenzi online din tara sa aduca asa ceva :angry:
Vreau sa vad si eu ca crapa acumulatorul ala life, numai pt. 0,4V diferenta..... :o....de multe ori uit sa ma dau selectie pe liion de pe lipo si incarc liion pe 3,7 de n-are aer
Aceasta postare a fost editata de zgr_44: 04 May 2008 - 09:20 PM
Postat 04 May 2008 - 11:00 PM
Cand incarci li-ion (3,6) pe tensiune de lipo (3,7) cat de mare este diferenta? 0,1V? Daca poti sa-i incarci si la 10V esti liber, sunt banii tai, timpul tau, si stii cel mai bine care-ti sunt prioritatile.
Cand dai citat nu citesti mesajul pe care-l incluzi? Am spus, si ma citez: "Cand iau in calcul asemenea curenti, ma refer la solutii de back-up, sau de stocare a energiei, pentru solutii alternative." Am vrut sa scot in evidenta acest aspect care pe mine unul ma intereseaza dat fiind ca tot pe aceasta arie TEHNICE, se dezbat si asemenea subiecte de energie alternativa.
Tot legat de citatul meu, in al doile link, daca vei citi, vei gasi urmatorul pasaj:
"A great advantage of LiFePO4 batteries is their extremely long life. For a standby power application such as battery could be expected to have a life of up to 20 years.
Lead acid batteries generally have a life of only a few hundred deep charge cycles while a quality LiFePO4 battery can typically be charged in excess of 2000 times and there are LiFePO4 cells which are currently under test at the US Department of Energy Laboratories in New Mexico which have recently passed 7000 cycles and are still working."
Nu stau sa dau quote la tot articolul, si nu este singurul disponibil pe net.
Nu prea ma pricep la modelism, deci nu ma bag in discutie, constient fiind ca de la asemenea tehnologii de cer curenti mai mari decat ratingul lor, de genul 10C, 15C, 20C.
Sper sa ne intoarcem la subiect.
#19
Postat 05 May 2008 - 09:52 AM
Miezu_eu, la 4 May 2008, 10:17, a spus:
acumulatori 123A gasesti la gpbateries.ro
eu mi-am luat acum vreo doi ani, pt o lanterna Surefire.
#21
Postat 09 May 2008 - 06:06 PM
Sper ca primul posesor de tehnologie sa vina cu asa zise date palpabile B)
Fulgerica poti sa ne dai cateva date, deoarece nu prea-mi vine a crede ca ai cumparat asemenea tehnolgie acum 2 ani, sa nu fie o baterie al carui nume sa semene sau ceva, pentru ca oricum ai privi problema, acumulatorii sunt numiti A123, oriunde in lume si nu 123A.
Nu o spun cu rautate, ci nu-mi vine a crede ca romanii s-au grabit sa aduca deja asemenea tehnologii, cand inca erau foarte putin raspandite. La ce pret au fost? Cu ce i-ai incarcat?
#22
Postat 09 May 2008 - 07:05 PM
p990i, la 4 May 2008, 11:55, a spus:
political (in)correctness,
dumping
in aceeasi ordine de idei...,
magazinele d'afara beneficiaza nestingherite de ...... linkuri....
0728.26.93.19
#23
Postat 09 May 2008 - 07:43 PM
fulgerica, la 5 May 2008, 09:52, a spus:
Le incurci putin, aceia sunt CR123A si nu sunt acumulatori ci baterii litiu si atat.
GP nu are listat nici un lifepo4. Regrete...
#24
Postat 10 May 2008 - 12:23 AM
IlPadrino, la 9 May 2008, 19:05, a spus:
dumping
Sunt convins de anumite aspecte, si de aceea este foarte bine sa se posteze si aici ce a gasit unul sau altul. Cu link-urile din tara inteleg ca se poate interpreta ca reclama, dar macar cele straine sa fie aduse la cunostina publicului larg. Cele interne le vom imparti prin metode clasice pm, mess, etc.
#25
Postat 10 May 2008 - 12:47 AM
renatoa, la 9 May 2008, 19:43, a spus:
adevarul e undeva la mijloc. nu sunt nici bateriii, sunt acumulatori li-ion in capsula 123 :rolleyes:
#27
Postat 10 May 2008 - 10:53 AM
Ei trimit cu posta express si toate comenzile care le-am avut la ei au venit in 4 zile.
De ex la o comanda de 1000$ de aprox 5kg si un kit de avion pretul transportului a fost de 75$, pt comenzi de 2-400$ transportul e in jur de 45$.
#28
Postat 11 May 2008 - 10:08 AM
Aceasta postare a fost editata de melsoft: 11 May 2008 - 10:08 AM
#29
Postat 11 May 2008 - 10:21 AM
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#30
Postat 27 May 2008 - 09:58 PM
30C rata de descarcare, suporta si varfuri de 60C.
Probabil la cantitati mai mari se pot negocia preturi mai bune, macar pe transport.
Pun link, desi n-o sa reziste prea mult (dupa un timp paginile ebay expira): http://cgi.ebay.de/A123-6-6V-4600mAh-30C-L...1QQcmdZViewItem
Se poate plati cu PayPal, care de curand merge si in RO.
