Modelism - RHC Forum: probleme motor pe benzina in sarcina - Modelism - RHC Forum
probleme motor pe benzina in sarcina barcuta de viteza
#1 Useril este offline   cristian cris
  • Postari: 60
  • Inregistrat: 16-May 09
Postat 11 August 2009 - 11:07 PM
Salut...am un model pe benzina cu motor 26 cc ...lasand la o parte faptul ca porneste destul de greu,in sarcina,in momentul cand e in apa,cand accelerez pur si simplu moare motorul...nu se opreste...doar ca se tureaza pana intr-un punct si apoi moare...imi puteti da vreun sfat,vreo idee???si inca ceva...sunt incepator in ceea ce priveste aceste modele...imi puteti spune de unde se regleaza benzina,aerul,etc???multumesc...am pus si niste poze cu modelul...
  • Imagine atasata: 08082009054.jpg
#2 Useril este offline   cristian cris
  • Postari: 60
Postat 11 August 2009 - 11:10 PM
alta poza....Imagine atasata: 08082009053_001.jpg
#3 Useril este offline   cristian cris
  • Postari: 60
Postat 11 August 2009 - 11:11 PM
alta foto..Imagine atasata: Motor.jpg
#4 Useril este offline   cristian cris
  • Postari: 60
Postat 11 August 2009 - 11:16 PM
o alta poza Imagine atasata: 08082009052_002.jpg
#5 Useril este offline   AG-74-HESS
  • Postari: 3573
  • Inregistrat: 04-February 08
Postat 14 August 2009 - 09:49 PM
Cum se raceste motorul? Cumpara alt motor si pune-i o pompa de apa.
http://www.rcboatson...dex.php?cPath=1
Its 26cc pull start 2-stroke engine with water-cooled pump. It runs on gas and oil mix. It comes complete with a radio control. Measures: approximately 51" long and 17 " wide. Great craftsmanship! No need for trim tabs as the hull is slightly curved at the back for stability. This Remote Control boat is truly ready to run. Compare other boats and be sure you are getting a "ready to run" INCLUDING THE RADIO! Just add gas and batteries and go race!
Aceasta postare a fost editata de AG-74-HESS: 14 August 2009 - 10:01 PM
#6 Useril este offline   nch
  • Postari: 1121
Postat 14 August 2009 - 10:03 PM
Raportul stoechiometric trebuie sa fie cu buba!
Sfat de fost mecanic auto cu vechi tabieturi.:
1. Motor facut bucati!
2. suruburi, jicloare
3. baie cu decanol
4. suflat cu aer la vreo 7 Atm pe toate goorile :D
Daca nu merge cumperi unul nou :D Deja la 26cc seamana cu mobra mea la 49 cc
0745.356.013
Bucuresti/Rahova
#7 Useril este offline   didisoft
  • Postari: 28
  • Inregistrat: 11-July 08
Postat 17 August 2009 - 12:25 PM
Lasati omul si nu-l mai indemnati la cheltuit si alti bani.
Barca este ok si motorul la fel.
Singura problema este ca pe ambele scrie China.
Motivul pentru care se ineaca motorul este ca nu ai reglat bine amestecul.
Aceste motoare trebuie reglate in sarcina. Adica tii ligheanul in apa cu o mina si pui pe cineva de incredere sa apese pe acceleratie. Cu cealalta mana reglezi amestecul pana canta motorul la maxim.
Eu cel putin asa am facut.
Ar mai fi o chestie. Barca mea care are acelasi motor, pana se incalzeste motorul, face la fel. Dupa ce se incalzeste este alta chestie.
Daca spui ca si porneste greu atunci scoate bujia si vezi daca este umeda. In acest caz inseamna ca intra prea multa benzina fara suficient aer adica amestec prost.
Curata bujia ci pune-o la loc.
Daca ai carburator de ala care nu are reglaj de amestec, nu mai stiu ce sa zic.
Pune-i si o pompa de apa pentru racire ca nu strica.
#8 Useril este offline   didisoft
  • Postari: 28
Postat 17 August 2009 - 12:30 PM
Revin.
Surubul de sus este de mers in gol (relanti) Din acesta reglezi turatia astfel incat sa nu risti sa se opreasca motorul cind iei degetul dupa acceleratie.
Surubul de jos este amestecul.
Invarti spre dreapta si dai mai mult aer, Invarti spre stanga si dai benzina.
Reglajul se face cu filtrul de aer montat.
#9 Useril este offline   AG-74-HESS
  • Postari: 3573
Postat 17 August 2009 - 08:57 PM
Ca o tine sau nu in apa este tot una, deoarece el nu mai are pompa de apa, deci nu va avea racire decat daca barca va inainta (destul de repede). Daca a facut teste fara racire, motorul nu mai e OK.
#10 Useril este offline   cipri_tezaur
  • Postari: 875
  • Inregistrat: 06-May 09
Postat 18 August 2009 - 12:24 AM
Vezi postareacristian cris, la Aug 12 2009, 12:16 AM, a spus:
dai relantiul mai mareincat sa nu moara,strangi surubul 2 de tot si incet il destrangi pana il auzi ca mere la turatia cea mai mare la un moment dat daca tot il desfaci o sa scada turatia sau o sa moara motorul (parerea mea)
#11 Useril este offline   ipsihi
Postat 18 August 2009 - 08:18 AM
Vezi postareacipri_tezaur, la Aug 18 2009, 01:24 AM, a spus:
...super !!!
#12 Useril este offline   didisoft
  • Postari: 28
Postat 18 August 2009 - 10:44 AM
Vezi postareaAG-74-HESS, la Aug 17 2009, 09:57 PM, a spus:
Asa este. Dar macar simuleaza functionarea in sarcina a motorului.
Motorul poate merge cam 1 minut fara racire.
Asta recomand si eu. Pompa de racire neaparat.
#13 Useril este offline   AG-74-HESS
  • Postari: 3573
Postat 26 August 2009 - 03:08 PM
Ce ai mai facut cu motorul? Merge? Intreb deoarece ma bate gandul sa ti-l vand pe al meu... ;) Nu are rodajul terminat. Evident primesti si pompa de apa noua ca bonus.
Am glumit, poate nu e cazul, dar e o varianta, decat nici una....
Aceasta postare a fost editata de AG-74-HESS: 26 August 2009 - 03:09 PM
#14 Useril este offline   cristian cris
  • Postari: 60
Postat 28 September 2009 - 09:10 PM
sal...l-am aranjat...merge super...am curatat carburatorul...schimbat garniturile la carburator...bujie...si start...e ok acum...o sa incerc sa pun un filmulet pe youtube...oricum ...ms tuturor pentru sfaturi...am luat de la fiecare cate ceva...si a folosit...ma gandeam la un zenoah in caz ca nu mergea...dar mai astept...
#15 Useril este offline   cristian cris
  • Postari: 60
Postat 05 July 2010 - 03:51 PM
Vezi postareacristian cris, la Aug 11 2009, 11:07 PM, a spus:
Salutare tuturor...de curand am schimbat motorul pe care il aveam la aceasta barcuta si pe care cu ajutorul vostru reusisem sa il pun la punct destul de bine,insa desi mergea fara probleme voiam totusi ceva mai nervos...asa ca am achizitionat un CRRC PRO GW26i...se comporta destul de bine,e mult mai nervos ca cel dinainte...am insa o problema...la care va cer din nou ajutorul...cand accelerez spre maxim barca are tendinta de a zbura efectiv...se ridica f mult si trebuie neaparat sa reduc...ce ma sfatuiti?exista vreun upgrade pentru stabilitate marita sau ceva de genul acesta?va multumesc
#16 Useril este offline   sonic xz
  • Postari: 797
  • Inregistrat: 26-October 07
Postat 05 July 2010 - 08:34 PM
Baga plumb, echilibreaza barca, regleaza strutul astfel incat sa ai unghi negativ.
#17 Useril este offline   Zue
  • Postari: 1495
  • Inregistrat: 05-January 07
Postat 05 July 2010 - 09:15 PM
cred ca barca ta este supermotorizata....trebuie sa ai grija ssa pastrezi acelasi CG si sa accelerezi mai usor (nici la electrice nu este indicat sa dai full gaz din prima) si astfel protejezi si motorul
tel.0745026562
#18 Useril este offline   cristian cris
  • Postari: 60
Postat 05 July 2010 - 10:02 PM
...multumesc ambilor pt raspunsuri...tot cautand pe net am gasit acele flapsuri (trim tabs ...nu stiu insa ce rol au...credeti ca ma ajuta cu ceva in ceea ce priveste stabilitatea?ms
#19 Useril este offline   petcanu
  • Postari: 123
  • Inregistrat: 10-January 09
Postat 27 July 2010 - 07:53 PM
Vezi postareacristian cris, la Jul 5 2010, 04:51 PM, a spus:
daca se ridica nu e problema, la viteza mare ar trebui sa se niveleze, daca nu incearca sa duci motorul mai in fata.
la modelele cu benzina in cazul in care ai motor mai slab. cum ai avut inainte, motorul se monteaza in spate. daca ai motor puternic trebuie montat mai in fata. incearca la un strungar sa iti faca o bucata metal pt prelungire pe care sa o sudez, lipesti de ambreaj.
acuma am vazut ca nu mai ai loc in fata.....pffff
Aceasta postare a fost editata de petcanu: 27 July 2010 - 07:55 PM
#20 Useril este offline   RC1
  • Postari: 453
  • Inregistrat: 25-July 08
Postat 04 August 2010 - 09:44 PM
Vezi postareacristian cris, la Jul 5 2010, 11:02 PM, a spus:
http://www.rhcforum....showtopic=23031
Ajuta mai ales daca nu ai cum sa umbli la centru de greutate
#21 Useril este offline   cristian cris
  • Postari: 60
Postat 16 August 2010 - 09:44 PM
Vezi postareapetcanu, la Jul 27 2010, 07:53 PM, a spus:
salut...nu are ambreiaj acest tip de motor...o sa ii fac eu unul...si in felul asta motorul o sa se mute automat mai in fata..ms pt sugestie...
