Modelism - RHC Forum: 2.4G - Modelism - RHC Forum
2.4G micro heli
#1 Useril este offline   takeoff
  • Postari: 1029
  • Inregistrat: 25-July 08
Postat 27 August 2008 - 09:31 AM
Vrem nu vrem se apropie iarna,terenul de zbor va deveni sufrageria,asa ca ce spuneti de:
Walkera HM 4#3B Micro Helicopter (2.4Gz Edition)
1). Overall Length: 185 mm
2). Tail Motor: N51 (Strong magnet)
3). Main Rotor Diameter: 180 mm
4). Tail Rotor Diameter: 50 mm
5). Drive Motor: 1215 (Strong magnet)
6). Transmitter: WK-2401
7). Battery: 3.7V 400mAh Li-Po
;). Gyro: Built-in
9). Receiver: RX-2406
10).Servo: weight 3.5g ;speed 0.11sec/60o(4.8V); torque 0.30kg/cm(4.8V);dimension 17.5*6.5*21.5mm
11).All-up Weight: 48g (Battery included)
Features
1). Compact 90¡ã swashplate structure is adopted and easy-to-be-mounted parts like servo are used;
2). Brushed motors offer powerful drive;.
3). 4-in-1 receiver includes the functions of both Servo Extent Adjustment and Built-in Gyro Sensitivity Adjustment;
4). High volume Lithium polymer at 3.7V 400mAh provides 7- to 10-minute flight after fully charged, depeding on your flight;
5). The usage of 2.4G technology is prompter in reaction, more sensitive in operation, and stronger in anti-interference.
#2 Useril este offline   thenenea
  • Postari: 102
  • Inregistrat: 10-November 07
Postat 27 August 2008 - 10:02 AM
Vezi postareatakeoff, la Aug 27 2008, 10:31 AM, a spus:
Suna interesant, ma uitam si eu la varianta "metal edition" cu tot cu valiza pe ehirobo (130$ + livrare). Nu prea stiu cat de buna e electronica la ele si cum nu sunt contrarotative daca gyro-ul nu te ajuta o sa fie cam dificil de tinut in aer.
#3 Useril este offline   ave
  • Postari: 1010
  • Inregistrat: 13-December 07
Postat 27 August 2008 - 11:53 AM
Vezi postareathenenea, la Aug 27 2008, 11:02 AM, a spus:
Mie-mi plang ochii dupa unul d-asta de 2 saptamani, dar din pacate tre' sa trimit bugetul in alta parte... :)(
Ave
  • Postari: 2647
Postat 27 August 2008 - 12:37 PM
Am un HM4, cu multe ore de zbor.
- dificil la pilotat (nu il recomand pentru incepatori)
- cam mare pentru interior si mic pentru exterior
- foarte- foarte dificil cu piesele de schimb
- calitate foarte slaba a tuturor componentelor
#5 Useril este offline   Primus
  • Postari: 3026
  • Inregistrat: 14-June 07
Postat 27 August 2008 - 02:16 PM
Hai Vlade ca le-ai zis tu pe toate :)
#6 Useril este offline   takeoff
  • Postari: 1029
Postat 27 August 2008 - 03:20 PM
Mai vlade tu tii cu ursul,intrebarea nu se referea la incepatori,mic pt. interior?;are19cm,este cat un creion.Piesele nu ca nu sunt de calitate sunt firave,dar cum a spus thenenea este si vrianta metal edition.Iar piese poate se indupleca vreun distribuitor local.Acum sa nu crezi ca fac apologia produselor chinezesti.
#7 Useril este offline   vlad1
  • Postari: 2647
Postat 28 August 2008 - 10:37 AM
Mi-am spus si eu o parere. Tin unul de citiva ani in vitrina, cu incarcatoare, cu statie cu..... Walkera are distribuitor unic in europa (acela nu e la noi)....
Cum ziceam e doar un sfat, nu e obligatoriu.
#8 Useril este offline   VIPER
  • Postari: 1506
Postat 28 August 2008 - 05:48 PM
Nu-l vinzi? :mellow:
Flickr - pozele mele
#9 Useril este offline   vlad1
  • Postari: 2647
Postat 29 August 2008 - 07:14 AM
Ba da, walhera #04 complet - (in conditie de zbor) + sasiu central + tub coada (noi) + diverse piese folosibile - 250 ron
