Modelism - RHC Forum: Vaselina - Modelism - RHC Forum
Vaselina De care? La ce?
#1 Useril este offline   OCRV
  • Postari: 342
  • Inregistrat: 29-March 06
Postat 09 July 2007 - 10:09 AM
Am tot incercat sa aflu ce vaselina sa folosesc la diversele parti ale modeleleor.
Din pacate nu am reusit sa ma dumiresc.
Am folosit vaselina Robbe (de la concurenta) dar nu sunt prea multumit (in special la diferentiale - parca se topeste)
As dori sa aflu ce vaselina trebuie folosita la:
-Diferentiale si angrenaje (includ piese de plastic si metal) (turatiile sunt sub 20000 rpm)
-La bucsile motoarelor electrice
-La capetele de planetare (fara manson de protectie)
Si care este diferenta intre urmatoarele tipuri de vaselina:
-siliconica
-ceramica
-cu litiu
-cu Bisulfat de Molibden
-cu grafit
etc.
In prezent am urmatoarele tipuri de vaselina:
-Tamiya Molybdenum Grease: http://www2.towerhobbies.com/cgi-bin/wti00...p?&I=LXGS04&P=7
-Tamiya Ceramic Grease: http://www2.towerhobbies.com/cgi-bin/wti00...p?&I=LXGS07&P=7
-Traxxas Silicon Grease: http://www2.towerhobbies.com/cgi-bin/WTI00...0001P?&I=LXJH95
-Traxxas Grease White Lithium: http://www2.towerhobbies.com/cgi-bin/WTI00...0001P?&I=LXDDW2
-Woodland Scenics White Grease w/Teflon: http://www2.towerhobbies.com/cgi-bin/wti00...IL=++&search=Go
-Robbe prazisionsfett No. 5532 (Teflon grease): http://at.robbe-onli...t.storefront/en
-OKS 400 (MoS2 Multipurpose High-Performance Grease)(100g): http://www.oks-india...f/OKS%20400.pdf
-OMV Signum L2 (Litiu)(400g): http://avostar.ro/in...p?productID=188
Nota: Rulmentii din diferentiale ii gresati cu ulei sau folositi tot vaselina din angrenaj (la mine rulmentii sunt incapsulati si nu cred ca intra in ei vaselina. Cum ungeti rulmentii?
"Eu lucrez 24 de ore pe zi ... uneori si noptile"
Postat 09 July 2007 - 03:47 PM
rulmentii incapsulati au din fabricatie o vaselina speciala in ei...nu trebuie unsi...
Dex
